Vewlix back sliding panel (with ethernet panel mount cutout)
socalcade
Southern California
Working on a replacement back panel that'll house the ethernet panel-mount component I bought, as well as do a better job than the janky half-slid-open factory approach. Would love to get a rubber grommet installed at some point too.
*edit* oops, turns out the opening cut into the cabinet by the factory isn't as wide as I expected. I need to shrink the cable opening and move the ethernet jack closer.
Much better! That black cable running off to the left is the cabinet's power, which actually runs inside my cabinet to a smart power strip. A control panel button (aux panel) is wired to my PC's power switch, and that turns everything on. Blue cable is ethernet, the white cable is for the LED strip stuff (janky for now...i know..) and you can see the speaker wires which run outside the cabinet to my subwoofer. Not a complete quick disconnect setup, but definitely better than it was with the factory panel.
It’s kind of a specific ask, but Could you make one that has a mount for the neutrik Ethernet, HDMI and a male DB15 Socket?
I don't have any of those components, but here's the Fusion360 file that wouldn't be too hard to tweak. For my ethernet component, I used the diagram from the Amazon listing but I did have to guess on the filleting of the rounded corners. Turned out near perfect!
