Hello all. Got a Vewlix L from a seller but unfortunately it's missing quite a bit of parts. Before I tackle the missing back door and front door I'm trying to figure out if my monitor is good.
Model number on the monitor is T32H07S(KA). I messaged the seller a while back and said that I didn't have a way to power the monitor as it looks like its power comes from a 8 pin connector that is missing.
They sent the following:
I guess first of all does anyone know if this would be the correct power supply to power this monitor?
The next issue I run into is these connectors are not the same size. Is it fair to assume I would splice in a connector big enough but leave the wiring layout the same? They also missed out on sending the connection to power this unit but most likely I can manage that as it looks like its only Line and Neutral I need to wire in.
Does anyone have an old harness that they don't need after upgrading?
Honestly, this isn't what I expected for $1250 but as the seller is a friend I'm trying to solve as many problems as I can without bothering them.
Appreciate any guidance. Thanks!
