VGA16 FPGA based Scan-Doubler for the Neo Geo
beharius
Istanbul
VGA16 Scan-Doubler for the NEO GEO
We are releasing an FPGA based line-doubler for the Neo Geo MVS arcade boards which is installed internally. It's outputting a progressive VGA signal (640X480) by tapping the digital video signals from the board. There is no loss in video quality and no lags since a frame buffer is not used. Its FPGA line doubles the signal on the fly (264 lines to 528) then handled by a DAC similar to the original Neo Geo design which converts it to analog video. Hence it's refresh rate frequency is off spec(59.1856Hz) instead of the required 59.94Hz for the 640x480 video timing format, more tolerant VGA output was preferred instead of the strict HDMI standard for compatibility issues.
The installation is very simple unlike the other internal digital video mods out there. There are only 20 wires to be soldered. It uses 5 bits per each RGB colors(5x3), a sync signal, a CLK signal taken from the 68000 CPU(or mainboard), 2 grounds and a 5V. So 20 wires in total. These are all next to the 74ls273 latches, on the resistors.
This mod also offers Scanlines and Pixel Blending features. These can be set by the jumpers on the board or a dip-switch to be installed on the enclosure. You can set its density by setting jumpers as 00 none,01 low,10 medium, 11 high. Pixel blending give a nice CRT experience for the user.
MV-1F installation
MV-1C installa
Package includes all the required wires for the installation, please note that final boards will have an 20pin IDC socket, so only wires for the MVS mainboard need to be soldered. We will also release a limited edition, premium Consolized MVS to commemorate our 7th anniversary. This will feature a car painted high quality metal enclosure including VGA(480p) and Scart(480i) outputs. An original, upgradable UniBios. Each bios can be individualized for your needs(name, serial etc.) too.
Price will be $100 including shipping. Pre-ordering TBA soon.
It's developed by our new FPGA coder, Eins, a very experienced designer in this field. So more to come soon...
BEHARBROS
www.beharbros.com
Finally we completed this project. It's completely redesigned and we added some new features after taking into account dear Mikejmoffitt's considerations. Both DAK and SHAD signals are processed now.
In addition to the VGA output, YPbPr output is also offered. It's selected with a dipswitch and both can't be used at once. We also separated and moved the Clock signal which can be soldered with a supplied coax cable for flawless performance. It's thoroughly tested on single slot boards only, probably works on others as well.
It will be released on Thursday(Jan 2nd) for pre-ordering on Beharbros.com, we can deliver them in 3 weeks probably.
The installation is so easy which requires a basic soldering skill, you may still need help from a modder/installer. We won't be providing installation services as we are very busy. It will be also used in our forthcoming Consolized MVS.
Price is $95 including shipping (DHL Express shipping (1-4 days) is optional for $10)
Package includes all cables,connectors and standoffs needed for installation.
Installation schematics will be released soon.
