XeD
I was ask to consolise a cps3. What are people using these day for composite , s-video, component, and hdmi out put? Am I better telling the guy to get the OSSC?
Since the CPS3 is Jamma-based, I'd personally recommend getting a JROK "RGB to Component Video, Composite Video & S-Video Encoder ( v4.x )" and one of their Sync Strippers (in case you need it):I was ask to consolise a cps3. What are people using these day for composite , s-video, component, and hdmi out put? Am I better telling the guy to get the OSSC?
I gave my Gonbes away (good riddance to bad rubbish) but yes if I remember correctly it WILL accept 15khz RGB via VGA port IF C-sync is wired to pin13 (normally H-sync in VGA head).does wiring RGB to VGA work on gonbes or ossc for both 31khz and 15khz?
Thanks for the reply. Only reason I want RGB from the Dreamcast is because both King of Fighters 99 don't work on VGA. Plus Jojo's didn't originally work (But this is a mute point). Apparently the H/V-syncs are active in RGB mode. but I don't know what signal its sending, so I don't know if I have to wire the C-sync as well. I might have to put that on a switch. As far as VGA boxes go, they're hard to findI gave my Gonbes away (good riddance to bad rubbish) but yes if I remember correctly it WILL accept 15khz RGB via VGA port IF C-sync is wired to pin13 (normally H-sync in VGA head).As for the OSSC, no analog lowpass filters on VGA port... So even if it would accept 15khz that way (never tested it and never will) it would be inferior to SCART connector (which includes filtering).does wiring RGB to VGA work on gonbes or ossc for both 31khz and 15khz?
VGA port on OSSC is designed for 31khz video (separate H/V-Syncs) and if you want to connect a Dreamcast to it that way (VGA) it looks fantastic.
I would recommend against the internal VGA mod however, especially if you also want 15khz (but I have no idea why you would want that).
If (for some strange reason) you want 15khz RGB video from Dreamcast, wire up a SCART head to the end of that cord after making the necessary changes to a VGA box.
It (being the Dreamcast) sends what you tell it to send... Aka jumper it for VGA (31khz) and it spits out separate H/V-Sync, jumper it for SCART (15khz) it spits out C-Sync, the RGB pins are unchanged.but I don't know what signal its sending
I know what the syncs are well enough. Obviously not nearly as well as an electrical engineer. I was just reading that when you set the jumper for RGB the H/V-Sync are still on. I was curious as to what was coming out of them, when the Dreamcast outputs the C-Sync for RGB. Like; are those frequencies still at 31 khz? But yeah, I know the RGB stays the same, I was just wondering why H/V-Sync are still on in RGB mode.It (being the Dreamcast) sends what you tell it to send... Aka jumper it for VGA (31khz) and it spits out separate H/V-Sync, jumper it for SCART (15khz) it spits out C-Sync, the RGB pins are unchanged.but I don't know what signal its sending
Again another reason why you should buy a VGA box over a internal mod solution... And I'm not trying to be mean here... You don't understand sync modes (or the selecting of these modes via grounding) associated with frequency. Please don't experiment on a working Dreamcast, or at least do a bunch more reading before you do.
You may find the quality of the Gonbes acceptable, but once you've seen it side-by-side with a "real" solution (Mini or OSSC) you'll understand.![]()
Weird. I heard clones are really bad. While I'm not saying mine isn't one, cause I don't know for sure (Got it from Paradise), I have none of these issues. Do you think you've gotten a bad apple?Even after extensive modifications, I was really unhappy with the Gonbes (recapped, sync stripped, etc). The video was full of artifacts and shimmering, and is very shaky. I'd be happier playing emulated CPS3 than going back to that honestly. I'm glad to be past that era when I messed around with cheap encoders.
I've had to use them in a pinch, but only for someone elses machine. It just sucks that it seems the only options are the $20 or $30 gonbes POS, or jump to $200 or $300 for xrgb/ossc. I wish there was a halfway decent option somewhere in the middle.Gonbes isn't exactly a name brand, there all cheap low-cost china products. The "good ones" have some improved pre-configured settings from vendors who placed large enough orders to demand they shipped with their desired settings, but all of them have horrible lag and the scaling mechanism is pretty terrible and you get very inconsistent results depending on what system you're converting.
you and me both...I've had to use them in a pinch, but only for someone elses machine. It just sucks that it seems the only options are the $20 or $30 gonbes POS, or jump to $200 or $300 for xrgb/ossc. I wish there was a halfway decent option somewhere in the middle.
Given it is open source, I've never actually seen the source or the PCB manufacturing files offered up for those who want to roll their own device (though I do know they sell a bare PCB option) - I assume that's why you put "open source"?you and me both...I've had to use them in a pinch, but only for someone elses machine. It just sucks that it seems the only options are the $20 or $30 gonbes POS, or jump to $200 or $300 for xrgb/ossc. I wish there was a halfway decent option somewhere in the middle.
seriously the OSSC is "open source" right? I'm waiting for the Chinese to start manufacturing them in bulk and selling them for pennies on the dollar... you know the dooms day thing that everyone says will happen to open source hardware...
You aren't thinking big enough my friend...seriously the OSSC is "open source" right? I'm waiting for the Chinese to start manufacturing them in bulk and selling them for pennies on the dollar
TV manufacturers no longer care about low resolution inputs. You are lucky if your new TV even has them, let alone processes them reasonably. Most people with high end setups already rely on external AVRs to handle their inputs and upconvert everything to HDMI for their display.You aren't thinking big enough my friend...
Imagine if you will, a world where LG integrates the components of the OSSC onto a successor to the B6 OLED and then offers a SCART port directly on the back of the unit!
How many of us would buy a TV like that?With the promise of 240p 5x 4K SCART support right out of the MF'n box!!!!!1111
Sad but true... Again the original point however, why is nobody cloning the OSSC (set-top box or otherwise)?I'm not at the mercy if the manufacture screwing it up to try to cut corners.
Because the universe hates usSad but true... Again the original point however, why is nobody cloning the OSSC (set-top box or otherwise)?I'm not at the mercy if the manufacture screwing it up to try to cut corners.
