Terminating in DB15 for those who need it is also not difficult.
It did get me thinking... So yes the controls would need to end in DB15's for the HAS.But IF we wanted the harness to interface with the Vewlix PSU, it would need to include a HAS compatible power connector on it as well.
Splitting the RGBs signal without amplification is easy.
So if you only connected one device at a time no problem whatsoever.
For both (at the same time) however that would require some boosting of the signal, that could become tricky.
OSSC is a SCART based device, and lowering arcade RGBs to proper SCART RGBs levels is as simple as resistor/trim-pots on said lines.
It isn't needed if using a HAS like me, HAS drops the levels and even offers sync regeneration.
So the harness only needs to link power and controls (from the cab to the HAS) audio and video is linked directly from HAS only.
