jugu
So I bought this power supply brand new from Taito in June, and now appears dead:
http://www.weiya.com.tw/products_detail.asp?le=english&fid=27&pid=196&tCatName=POWER SUPPLY
I'm wondering if there's more I can do? I've done the following:
I haven't taken it completely apart as I've sent an email to Taito to see if these parts I've been buying have any kind of warranty.
And yes, I've been using a step-down converter to bring the voltage down to 100v.
Any help is appreciated. Thank you!
- verified deadness in a second cab
- fuse looks fine and has continuity
- Input voltage into the connector is good
- All the caps look brand new, no bulges, no leaks, no corrosion
- Old Wei Ya P271 from second cab works fine in both cabs, eliminates first cab wiring as suspect
