What is up with my Bubble Memories (Japan) board?
Pr3tty F1y
USA
So I popped open my Japan-region Bubble Memories cartridge and got a bit of a surprise:
The cartridge always struck me as a bit weird as the label on top is too wide for the plastic indentation.
I was expecting a more traditional board layout, but this thing looks to be all 27C4001 512kb chips (except for the sound EPROMs which are 27C2001's). I already slapped stickers over the EPROM windows, so no fretting there. However, the Taito security sticker was intact on the on the center screw of the cartridge before opening it (although that doesn't mean someone crafty didn't get in there).
Any thoughts on what this is? Am I wrong and this is what I should have expected?
It looks like the only sets in MAME that have 512kb roms are the prototypes. I'm not thinking that this actually is a prototype. Just maybe the same rom data split over different chips. However, I'll be dumping it to make sure.
I guess this gets around my question about how I was planning to do a Twin Qix conversion. Apparently, given everything is socketed, it will be a bit easier than anticipated.
Even weirder. This Japan region cartridge came with a Japan region F3 mother board, but the version of the game's test mode is 2.4O. Date stamp matches the v2.4O in MAME. However the MAME Set is 13.5mb across 13 ROM chips and this dump with 27 ROMs and is only 13.0mb. I've been trying to concatenate/hex search to see which of my roms match the MAME set and I'm not having much luck (but I'm also probably not trying that hard :-D).
OK - I can verify that this rom set is bubblem from MAME. It's just split over separate roms and interleaved. When deinterleaved and the separate data chunks are combined, it's a bit perfect match to the known bubblem set. So it's nothing new or special.
However, I'm still totally perplexed by the IC layout on this board. I can't find any other photos of anything that looks like it.
That makes sense. There are no Taito logos on the board, but the name Taito does appear twice and there are some D77 pals on the board - so I'm not sure where they would have been sourced from. It looks like an awful lot of effort for a F3 bootleg to have the board labeled and be using (potentially) real stock of D77 pals. (e.g. like would they have a bunch of these empty pcbs on a shelf and need them labeled so that they knew what they were? Or maybe the pcb designer just liked producing an elegant product ;-D). Granted, the use of 32 pin 512kb 27C4001's for everything probably was cheaper at the time than the larger 1mb/2mb 42 pin chips.
There's no indication on the board of when it was manufactured.
However, it was clearly made to mimic real Taito F3 rom boards as the rom sockets are labeled for the following corresponding ICs of the legitimate board:
  • Sprite data:
    • IC4 (split across IC4.0, IC4.1, IC4.2, and IC4.3 sockets)
    • IC8 (split across IC8.0, IC8.1, IC8.2, and IC8.3 sockets)
    • IC12 (split across IC12.0, IC12.1, IC12.2, and IC12.3 sockets)
  • 68K prog code:
    • IC17
    • IC18
    • IC19
    • IC20
  • Audio prog code:
    • IC32
    • IC33
  • Sound data:
    • IC38 (split across IC38.0, IC38.1, IC38.2, and IC38.3 sockets)
    • IC41 (split across IC41.0, IC41.1, IC41.2, and IC41.3 sockets)
  • Tile data:
    • IC43 (split across IC43.0, IC43.1, IC43.2, and IC43.3 sockets)
    • IC45 (split across IC45.0, IC45.1, IC45.2, and IC45.3 sockets)
    • IC47 (split across IC47.0, IC47.1, IC47.2, and IC47.3 sockets)
Of all of the split roms, the non-sound data roms (i.e., sprites and tiles) are from sockets .0 and .2 as alternating bytes as the first chunk of rom data and then sockets .1 and .3 as alternating bytes appeneded to that first chunk to generate the original rom file. For the sound roms for IC38 and IC41, they are assmebled as .0 and .1 as alternating bytes as the first chunk and then .2 and .3 as alternating bytes as the second chunk. So doing the reassembly in that manner produced the original bubblem rom set.
I'm going to play around and reverse my deinterleaving PowerShell script to see if I can convert some existing F3 sets to run on it :-D
