What tool do I need to remove the nuts from astro city panel bolts?
ACE1CC
Pittsburgh PA
I don't think I have the right socket size for this nut. Does anyone know the exact tool I need to remove these?
The nut will be a metric size instead the imperial sizes found in the US, but tbh you can just use a small adjustable wrench (I usually do this) or even pliers if you're careful. Maybe parallel pliers if you wanna get fancy.
Edit: the picture isn't too clear, but it looks like there might be some loctite applied on the bolt thread. I usually stick my soldering iron on the bolt for 30 secs or so in this situation, which will soften the loctite and make it much easier to take apart. Sanwa likes using red loctite on JLFs, which makes it super easy to strip screws when trying to disassemble them.
Yep, as nem said a 7mm socket is definitely the right tool for this job. If clearance is an issue you can pick up a deep socket said quite easily/cheaply and they can come in really useful too.
