Which pins do I need?
tonyt76
USA
Hey guys I’m going to try my hand at making my own wiring harnesses.
Which pins would I need for a 176288-1 amp connector?
Thanks!
175150-1 = Pre tinned Copper Alloy
175150-2 = Pre tinned Brass
I would suggest going with 175153-1 and 175155-1 as it is for 22-26AWG which is more typically sized for cabs. The 16-20s are pretty large in comparison
https://www.te.com/usa-en/product-175153-1.html
https://www.te.com/usa-en/product-175155-1.html
Unless of course you plan on using larger wires. There's some really bad advice on the AO wiki about these contacts to get them oversized so you can just squash or trim them down for smaller gauge wires, but crimping doesn't work like that. Best thing to do is check the AWG you're using and buy accordingly.
EDIT:
Digi-key links to tape& reel versions:
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/175151-1/1152993
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/175149-1/1136556
Digi-key link to bulk versions:
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/175155-1/1152996
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/175153-1/1149439
