Wiring NAC PSU's Rocker SW
erzane
CH
Pls can you confirm if my rocker SW wiring is correct? The former SW do have only 2 pins but my replacement SW do have four. Formerly, the SW was connected to pin 1 & pin 2 but I don't remember which wire was hooked to pin1 and which one to pin 2.
Also, my Fuse is 250V / 4A but the manual suggests 125V/4A. Can I use both? What happens if I use a 125V/3A?
Thank you!
The original is single pole, your replacement is double pole. It doesn't matter.
Doesn't matter. The switch is just opening the connection.
It's going to be fine. As long as you're powering regular boards and not plugging a computer in to the AC outputs of the PSU, it's not going to blow.
Noticed. Thank you!
Regarding the Fuse : Gradius IV Fukkatsu, VF3, SW Trilogy or Cave SH3 are considered as ok?
VF3 and SW Trilogy need a different power supply, but otherwise, yes.
I see. So I can also use a 125V 5A or even a 125V 10A to have more secure?
Fuses are there for overcurrent protection, like if there was a short. You don't want to go too high otherwise it defeats the purpose of having one.
