World Heroes Perfect: Gameplay Problems
Mageta the Lion
Germany
I just got a World Heroes Perfect for MVS and i have Issues with the gameplay. Rounds end "randomly" after 30 seconds (timers at around 70sec) and most/all projectiles have no Hit Box. I'm running the game on a single slot with a uni bios. Over a dozend other Carts run without issue on that setup. Is there a chance the setup is at fault or can i be "certain" that the Cart is at fault? (any way to make sure without a second motherboard?)
Thanks, clearing the Backup Ram seems to have solved my issues*. Curious how that worked, does the backup ram somehow influence the clock (would have been my total noob gues since rounds ended prematurely and Hitboxes didn't connect)?
*If someone stumbles on this and doesn't already know: Putting all dips to 'on' and powering the board clears the Backup ram
If you boot the game when the cart isn't making a good connection it can be glitchy and bad settings can be saved to the SRAM.
You can also clear the backup RAM by going to the Hardware Test menu.
