WTB: KiCAD help
rewrite
Multi Boyz Litigator
Multi Boyz
SoCal
Basically I need to get this dumper PCB changed a bit. It's in gerber format only so can't get edited, so it just needs to be recreated from scratch.
It is fine for producing a cart or two, but ill-suited for mass production.
https://github.com/xvortex/VTXCart/tree/main/Dumpers/Gerbers/CV_DIP
The two smaller 44 pin sockets sets are spaced too far apart.
The correct spacing is here:
https://github.com/jwestfall69/neogeo-161in1-dual-daughterboard
I would also like to:
- Extend the length of the PCB by the length of the dual daughterboard, so that it can be installed/removed without the programmer being removed.
- Add in 12 of the larger sized socket holes on each side of the opposite end in order to give some rigidity for removing the daughterboards.
Video explanation:
https://photos.google.com/share/AF1...?key=cjRzWlE0TUZSX3VYdWp3X2ZUaTc0Wnd0NTNESjRn
