Southern California
Looking to buy a monitor for my Sega Blast City that came empty without one. Located in Southern California.
Southern California
In case you aren't aware, the blast city used a NANAO MS2930 or MS2931 monitor. The MS9 was used in the Astro/New Astro. You would lack the trisync, and I'm not sure if it would physically fit (frame as well as tube curvature).
Awesome! Thank you for the info, now I can continue on my search for the correct monitor.
mR_CaESaR
Sydney, Australia
If you take a pic of your remote board inside the control panel, you can pretty much tell which chassis you'll need.
If it's just 3 buttons - 2931
If it's one with pots and dip switches to go from 15/24/31khz then it's the 2930.
Southern California
This Blast City i got came with no monitor in it. Tried it out with a monitor not sized for it and the cab is fully functional. Just need a monitor for it.
sarty51
Columbus, OH
A MS-9 will fit in a Blast City. The issue is the bezel. You have to kind of back mount the monitor to the frame and use some washers. This helps the monitor sit deeper into the cab. The bezel will then pop into place. Other than that yea the MS-9 tube has much more curvature to it than the 2930. MS-9s seem to be a lot more plentiful than the tri sync monitors. Probably a lot more stable too to be honest. You can always run hi res games through a converter such as the Capcom I/O. 2D games will look ok but the 3D games don’t look all that well unfortunately.
sarty51
Columbus, OH
Oh yea and you will need a 2930/31 frame to swap the monitor over to.
