andymage
china
- Tekken 6.0 vanilla
- Tekken 6 Bloodline Rebellion
- Tekken Tag Tournament 2 vanilla
- Tekken Tag Tournament 2 Unlimited
- Mobile Suit Gundam: Extreme VS. Full Boost
- Raizing Storm
- Deadstorm Pirates
- Deadstorm Pirates Special
- Dragon Ball Zenkai Battle Royal
- Dark Escape 4D
- Sailor Zombie
- Taiko no Tasujin Green
- Time Crisis Ryzing Storm
Differences between 357 and 369:
357A = PS3 Phat 256mb NAND (With extra crypto on HDD)
357C = PS3 Phat NOR
369 = PS3 Slim NOR
So each are same on GPU/CPU power so there isn't really any difference in performance side.
Reason why 357 games won't run on 369 and via verse is because of system specific checks and they use different HDD crypto.
You have to be very specialized in the PPC assembler and patch the DEX firmware to run on GEX to enable debugging. Different ATA, ATA TWEAK, ENCDEC keys.4x 256bit
HDD Key:​
https://www.psdevwiki.com/ps3/Namco_System_357
https://archive.org/download/357-b-...de-cok-002-tekken-nand-ros-197.000-251.040.7z
https://www.psdevwiki.com/ps3/Talk:Namco_System_357
Arcade firmware GEX:
https://archive.org/download/ps3-arcade-gex/Arcade (GEX) Firmwares/
https://archive.midnightchannel.net/SonyPS/Firmware/index.php?cat=gex
A friend of mine converted his CECHL00 (VER-001) to arcade and installed 4.40 GEX OFW after converting, his system fully bricked but he was able to fix it by reflashing, the system does not brick if he installs 2.51 or 3.10
This occurs because since firmware 4.30 an eid0 signature check was added in lv1ldr, lv1ldr would have to be patched in order for the firmware to run if you manually converted the unit and did not use a donor eid0 (from a real GEX dump for instance).
You know most of this information is old/false right?
If there are any errors, please point them out for me and I will correct them so that I will not mislead everyone.
I don't have more say in terms of arcade hardware because I rarely practice it, I just want to discuss this issue with everyone, and I believe everyone who owns 3xx hardware will also discuss this issue.
I don’t think it’s still the right time to share any information, it’s up to @Darksoft or @Mitsurugi-w imo…
