You started with the sarcasm, friend. I only replied in kind.don't see why the snark and resistance is necessary.
Yes I would LOVE to see the part numbers if possible. That would help alot of people hereBut they're not 'Molex' connectors, they're AMP/TE Universal Power connectors...? Are you referring to a different connector?
Digipen is a game dev school. Do you mean Digikey? If so, you can search with the part numbers I listed on the Digikey site.
Yeah but the part numbers are already there. I don't know if these aren't the ones you want or if you didn't notice.Yes I would LOVE to see the part numbers if possible. That would help alot of people here
Oh there’s the door..Yeah but the part numbers are already there. I don't know if these aren't the ones you want or if you didn't notice.
I can't decide if I should make a play on the old classic, and "Be sure it doesn't hit you as you exit, friend" or go for the always effective "It's a good thing you're pretty". So, have both!Oh there’s the door..
I’ll just shimmy my way towards it.
I’ll take it. Thanks for checking out my ass.I can't decide if I should make a play on the old classic, and "Be sure it doesn't hit you as you exit, friend" or go for the always effective "It's a good thing you're pretty". So, have both!
True. Just reserved for future use, I guess.Not sure why the extra button harness has wiring for 5V and ground but it isn’t connected to the PSU so you won’t get any voltage reading from it.
There's another connector for analogue games. And yes, it does - the analogue connector has two V inputs and two grounds.do analog controllers require some voltage? maybe it is used for baseball games.
