Heh, fair enough. Yeah, I'll take DZhay's advice and wait to see if something comes up. In the meantime, Superguns it is!I've got a blast city that is 100v and I just use a step down from ebay appears to work fine
Thanks for coming through mate! A+Happy to be a backup if worst comes to worst, I'm not too far from there.
Yea, my biggest issue is probably the logistics, because a lot of the time those freight companies charge quite a bit.@klee123 I got 6 of my 7 cabs locally in Brisbane, and one of them from Melbourne transported by Bill. They’re out there, you just have to ready to pull the trigger when they turn up and have logistics thought out.
Both probably 10Mhz A boards though which might not be ideal.Not my auction. Good deal for two CPS-1 boards for the upcoming multi. Split it with a mate or keep one for backup: https://www.ebay.com.au/itm/265046187225
Not exactly true. Details about how the multi will deal with speed haven’t been released yet
I've done loads of tests actually and discovered the attract isn't impacted by the CPU speed on CE (outside of the fastest memory access making "black screens" loading times shorter) but in game it's a different story with 20% speed difference.I dunno if I buy into this swapping the crystal on the non Dash boards man. They also have different CPUs - HD68HC000CP10 vs HD68HC000CP12.
Sure they *probably* overclock fine with the replaced crystal but CPS1 is a funny beast. For example SF2:CE appears to run properly on a 10Mhz board and its great for a casual bash but if you're right into the game - it doesn't tun the same as a Dash board. It's not something I would personally wanna do for high scoring runs for example.
Swap the crystal on a non-dash for a 12MHz and then behaviour is identical to a real DASH board.
Simply starting a round and looking at the countdown.In what sense do you mean 20% different, how are you calculating/observing that?
@YesAffinity what do you reckon? Does that seem right to you? I know I timed it once and didn't get that kind of result.Simply starting a round and looking at the countdown.
I posted videos a while back, somewhere... (with two CPS1 setups and two TVs in parallel, having inputs mirrored to both boards).
