sorry im horrible at wiring bare with me I understand now on the cute. I have a taito e3 i would like to use this in. If im gathering i would have to add a wire to jamma edge to get -5?
My understanding is that the Egret 3 is not wired for JAMMA but for JVS. You can replace the PSU in that cabinet with a QP-150-3A and this AWSD interface PCB but JVS boards don’t require -5V.
The Egret 3 is wired for JAMMA and has the additional JVS power harness. In the Egret 3, the 3.3v is routed to the JST VL connectors for JVS power. The Egret 3 also has a JAMMA connector but it is missing the -5V. You could add in the 2 pins that are in the -5v position on the JAMMA harness then route those (2) -5v wires to the Molex connector on the Egret 3. You should see that factory Egret 3 Molex connector is also missing 2 pins. So you should be able to add 2 pins on the JAMMA side, a small bit of wire and 2 pins for the Molex side. Once that is done, moving the solder jumper to the -5v position should bring the -5V all the way to the JAMMA edge.
