NathanDrake
FRANCE
Hi guys,
I have a strange problem with one of my lindy. I change the battery and try to do a CMOS but since the new battery installed no signal.
Things I try :
Try another battery
Check CG card , ram and JVS card all ok
Change Processor
Nothing works :(
If anyone got an idea.
Thank you
You remove RAM, graphics card, sound card, JVS card (You put the processor only) it seems to me that the motherboard emits "Beep".
If it doesn't beep, your processor or motherboard is dead
indeed, it's a pc.
so test with bare minimum.
motherboard & cpu,
a generic video card you know works, and ideally a different psu that you know works.
no cards, no ram, no pic/switch board.
and check the cpu fan spins - because if the bios doesnt see it spinning it can power the board down.
Salut El Nino,
Oui j’ai déjà essayé et elle bip effectivement.
C’est vraiment étrange j’ai tout essayé :(
Merci en tous cas
Hi stj,
I don’t have a generic video card but I try with another Lindbergh videocard same and test it on another Lindbergh it works well
I will try to do it with pic remove (I don’t test that)
I let you know
Thanks
Are you sure that your JVS card is working 100%?
I have already had JVS cards that worked with one game but not others ...
I also had JVS cards that prevented the motherboard from booting
