TheBortot
@l_oliveira do u have a clue?
Hispanic is actually the orange boards. Gray boards are ASIA region (Hong Kong/Singapore and other countries on the Asia region except Japan which is Green...). What discern other region boards from Brazil region boards is that the external casing of the B board are marked with a branding iron which says: "Certificado CAPCOM Qualidade ".Hispanic (Gray) cards.
I have two. One is in my Capcom Romstar machine produced here in Brazil in the 90's. The other was wanting to put on a machine that I'll have to do from scratch, a Big Blue Q-Sound from the USA. But if you want to see this Card Dispenser, it's working perfectly. My email: liperyu@gmail.comThanks for the photos, that's great! If you ever come across another, please let me know!![]()
-ud
Right. True, the Hispanic came in many orange plaques. Thanks for the correction.Hispanic is actually the orange boards. Gray boards are ASIA region (Hong Kong/Singapore and other countries on the Asia region except Japan which is Green...). What discern other region boards from Brazil region boards is that the external casing of the B board are marked with a branding iron which says: "Certificado CAPCOM Qualidade ".Hispanic (Gray) cards.![]()
Interesting. it seems that these are just "prize cards"The power of the Card Dispenser comes through the extra kick whip. In the image that is attached, comes the whole configuration.
Configuration of the wires in the kick whip.
In fact I do not know specifically what binds the strands pink with white, gray with white and blue with white. I'm a layman in electronics.Interesting. it seems that these are just "prize cards"The power of the Card Dispenser comes through the extra kick whip. In the image that is attached, comes the whole configuration.
based on that picture it seems that these are the wires used for card dispenser:
1 = [black/white] GND
3 = [red] +5V
5 = [yellow] +12V
7 = [pink/white] ??
22= [gray/white] ??
26= [blue/white] ??
with only 3 data lines I'd suspect 1 is an output to trigger a card to dispense and the other two are inputs for "empty" and "ready"
Which games supported the card dispenser?
Sir , the link doesn't work ! Cheers !
Try nowSir , the link doesn't work ! Cheers !![]()
I just found it ! Thank you FelipeTry nowSir , the link doesn't work ! Cheers !![]()
Leonard do you know how the codes were inserted in the Brazilian roms so that they had the option of turning the CARD DISPENSER on and off?Brazil boards can be anything, Green, Gray, Orange even Yellow (Yellow is supposed to actually be rental boards) but they will always be marked with that logo on them. Since the plastic is melted and then painted silver like that it's impossible to undo.
Nothing is inserted. The USA/JPN/EURO ROMs have the code to access the card dispenser, they just don't use it. Change the ROM region to BRAZIL and the card dispenser function will become available.Leonard do you know how the codes were inserted in the Brazilian roms so that they had the option of turning the CARD DISPENSER on and off?Brazil boards can be anything, Green, Gray, Orange even Yellow (Yellow is supposed to actually be rental boards) but they will always be marked with that logo on them. Since the plastic is melted and then painted silver like that it's impossible to undo.
I understood Leonard, and to change the region of the game do I have to burn eproms 3 and 4 for the Brazil region?Nothing is inserted. The USA/JPN/EURO ROMs have the code to access the card dispenser, they just don't use it. Change the ROM region to BRAZIL and the card dispenser function will become available.Leonard do you know how the codes were inserted in the Brazilian roms so that they had the option of turning the CARD DISPENSER on and off?Brazil boards can be anything, Green, Gray, Orange even Yellow (Yellow is supposed to actually be rental boards) but they will always be marked with that logo on them. Since the plastic is melted and then painted silver like that it's impossible to undo.
I do not get the "NO CARD" message in MAME, even if the 'C.DISPENSER' setting in 'ON'.MAME source code' said:- Some Hispanic/Brazil region sets have settings adjustable for a card dispenser.
Many times, this is defaulted to ON. Since MAME at this time does not emulate
this unique dispenser, you will get a "NO CARD" message flashing on the screen
for these sets unless you enter Service Mode and adjust CONFIGURATION > SYSTEM >
C. DISPENSER to OFF. An example of a game which does this is Street Fighter 3
Alpha.
