SelfDeniedHoarderz
Hi, these are all the steps that i've done:
1. Suicide the board - (checked)
2. Remove all the EEPROM - (checked)
3. I've solder the jumper accordingly to the guide and check using Multimeter - (checked)
SOOS SO
OSOSOS
SOSOSOSO SOSOSOSO
4. Install Pal G
I've removed the current one, replace it with the inlcuded Pal G from the kit
I bend pin number 9 and solder the wire to it. The other end attach to the J17 pin
5. I've check the board pins and they are all straight, no bended
6. I attach the boards correctly
Notes: I've solder the keywriter wires but those wires are not yet soldered to CN2 pins
7. I've used Windows 10 PC, format 16GB microSDcard FAT32 and copy "Old" decrypted set (which does not required soldering keywriter wires)
"Games" folder is placed at the root of the SDcard
RESULTS:
- Show only GreenScreen on TV (no sound)
- Nothing shows up on the LCD (even press all three small buttons do nothing)
- I've reseated this board 4 times (nothing works)
I just don't know what's wrong. Could it be that my Darksoft CPS2 kit is faulty?
Any advices or suggestions to troubleshoot this are greatly appreciated.
![8XaK5o6.jpg](https://i.imgur.com/8XaK5o6.jpg)
![JHmksWY.jpg](https://i.imgur.com/JHmksWY.jpg)
SOOS SO
![LF7IUKB.jpg](https://i.imgur.com/LF7IUKB.jpg)
OSOSOS
![oymSjaN.jpg](https://i.imgur.com/oymSjaN.jpg)
SOSOSOSO SOSOSOSO
![alKqcpO.jpg](https://i.imgur.com/alKqcpO.jpg)
4. Install Pal G
![QAKtfmV.jpg](https://i.imgur.com/QAKtfmV.jpg)
![FCqhx2p.jpg](https://i.imgur.com/FCqhx2p.jpg)
![jxSeMFv.jpg](https://i.imgur.com/jxSeMFv.jpg)
![C0IVzjy.jpg](https://i.imgur.com/C0IVzjy.jpg)
RESULTS:
![Itn9qgv.jpg](https://i.imgur.com/Itn9qgv.jpg)
![FvE0hLM.jpg](https://i.imgur.com/FvE0hLM.jpg)
![QPqEvlc.jpg](https://i.imgur.com/QPqEvlc.jpg)
