there are lots of ways to deal with power-planes,
one is to pre-heat the top with hot air and then desolder from the under side,
if you dont have hot air(you should as it's only €30) then desolder all the data pins with whatever method,
then heat each power pin and lift that end of the chip out.
then use stainless-steel needles to clear the holes out - or melt the solder from one side and use a pump on the other side.
