It must that they have different firmware installed.I can't understand yet why it's working for ekorz and not for noonan who have the same MVS configuration (MV1-C and Unibios 3.3)...
Yes, we are working on it.Is the red deadlock screen problem with KOF98 in MVS mode in the process of being solved right now?
thank you for the files.I've posted the previous version which was 1040 in case someone wants to roll back until we fix it.
flase
@[u]@hardyhell[/u] which sound issues or games not flashin issues do you mean?
as i told you in private message. My friends system just behaves the same. We have a stereo mvs system. And starting with this new firmware the flashing problems got worse. And also the sound problems. I sent you a video already.@hardyhell sometimes menu freezing when flashing games is possible and we are aware of that, but broken sound in any game on MVS Multi, I'm afraid that this is not an issue with the MultiMVS. The reason must be somewhere else.
Menu and firmware must go together, due to the many changes. Old firmware and new menu will be a no-no.The newest menu seems not to go so well with the older firmware you posted.
I know about it and I havent been able to reproduce it. Did someone else ever had this issue?They are gone when you switch from bank 1 to another and then back.
as you name it. Can you please post the menu that fits to the older firmware you posted?Menu and firmware must go together, due to the many changes. Old firmware and new menu will be a no-no.The newest menu seems not to go so well with the older firmware you posted.I know about it and I havent been able to reproduce it. Did someone else ever had this issue?They are gone when you switch from bank 1 to another and then back.
Maybe it depends on what slot model you use, i had a lot of sound problem with the multi mvs and my MV1F (stereo) doesn't matter what firmware & menu, but on my 2nd slot (MV1FZS,mono sound) i haven't any sound issue yet.I will report here if i have sound problem with the 2nd slot (MV1FZS).as i told you in private message. My friends system just behaves the same. We have a stereo mvs system. And starting with this new firmware the flashing problems got worse. And also the sound problems. I sent you a video already.@hardyhell sometimes menu freezing when flashing games is possible and we are aware of that, but broken sound in any game on MVS Multi, I'm afraid that this is not an issue with the MultiMVS. The reason must be somewhere else.
