Johnfan1986
Ok thank you ,The mod isn't difficult, but no one sells a pre-made pcb for the 1fz that I'm aware of.
You need to order the parts from digikey yourself.
Can you please elaborate? Was it working before? Or did you just buy it? When did it stop working? Have you tried going to the previous menu and FW ?I tried using the latest menu and I just get a black screen. Is there another link for the newest FW?
Hi sorry, I actually just got this working. Apparently the SD card had some sort of issue but it's going now. Weird but when I swapped the card it started working.Can you please elaborate? Was it working before? Or did you just buy it? When did it stop working? Have you tried going to the previous menu and FW ?
Yeah, one never had that happen before. The cheap no-name card seems to out perform the Samsung one.Glad to hear that. Another happy ending
Hi everyone, I could found another MV1 FS and test it. It looks in less good condition than the first one but still works this one is equipped with an unibios 4 and the battery is button battery (CF attached picture) . I first tested it with windjammer original game, no problem. Then I tried the multi with the game already installed, SVC, for 30 min and no unexpected reboot then I moved to Sengoku 2 and I had one unexpected reboot in game. Then twinkle star, the game didn’t start because I had an error message : “exception error handling” Then I did a reset I arrived to the menu and try again to boot on twinkle star but same error. After reset again I had 3 other games Samurai spirit 5, MOTW and bang buster. Bang buster and samurai spirit 5 worked perfectly for around 1 hour each. MOTW show the same “exception error handling”. Reset again and I tried Windjammer but like before with the first mother board I could even not open the introduction It reboots before the title appeared, then the same error appeared as well . See the attached picture.Ok thank you ,
for now I will try to found another MV1FS.
Hi, DarksoftWe will try to fix it in a new FW release. Can you test with Original BIOS and confirm if it works the same?
You mean take the original bios from its socket and put it to the new board ? After removing the unibios 4 ?Try it and let us know how it goes.
Hi, is there any advice for my issue ?Good evening everyone,
Some updates of my situation:
As recommended by Darksoft and Mitsurugi, I took the original bios from my first MV1FS, to put it in the socket of my second MV1FS recently purchased. Everything starts fine, windjammer was installed on slot 2 so I start with it and no problem the game start I could add the credits and play for 45 min. Then I moved to samurai spirit 5, no issue. Then I decided to tried MOTW. I installed it in slot1, start to play and no problem as well , I was very happy because yesterday I even could not see the introduction. I went back to the menu and added last blade 2 to replace samurai spirit 5. I tried MOTW again, no problem and then windjammer which started to give problem of the unexpected reboot of the game. Sometimes before the title screen it rebooted. Sometimes when I added the credits. It rebooted mainly times. Then I succeed to go back to the green screen it after black screen I could not enter to the menu. So I reset the system and went to last blade II which shows the introduction, I started to play but at one point it rebooted. I went back to the menu and the slot 2 was empty!!! Windjammer disappeared. Strange .
So basically the error green screen doesn’t appeared any more but still the unexpected reboot in game occurred. Usually je problem comes after 1h .
Good evening everyoneit’s probably fine. The chips want 5.00v. You can check a chip, try the bios at sp1. Pins 20 (black) and 40 (red). There may be a little drop off from the edge but probably not much
https://www.arcadiabay.de/images/elektronik/eprom/eprom_27C1024_pinout.jpg
It’s probably not a power issue, time to try another motherboard if you can find one.
