PascalP
Legendary
The Netherlands
Anyone know what the dips on a 369 do?
Can I change the output resolution with them?
Nobody has an idea?
want to find out if I can run it on my NNC with trisync monitor ;)
DIP SW #1 for TEST MODE and others doesn't seems to be affect.
TTT2 series only works with 720p display, i think only T6 series supports resolution change via dip switch.
Thanks, will give it a go!
is it possible to remove the HDD and browse the XMB like you would on a PS3 somehow?
Interesting how little information is to be found online of these systems... :(
Here you go chief. T6 ds sheet
Those aren’t for the 357/369 but rather the Chinese console knockoffs with a PS3/XBOX 360.
On an actual system, for the 357A/B, at least for Tekken 6, dips #1 is for the test menu and #2 is for 31khz 480p resolution. On the 369, only dip switch one functions as the test menu switch as the firmware in the 357C/369 seem to only output the games in 720p, not 480p. I think the other dips work for other games.
