24movements
California, USA
Hi there,
I have a machine that takes quarters with one of those new electronic coin acceptors, but it seems to miss coins a LOT. It's pretty frustrating trying to get it to work consistently, so I just want to change it to a good ole Coin Mech that always work.
The problem is the electronic ones use 4 pins to give it power and pulse when it receives coins. While the Coin mech only has 2 connections for the micro switch.
Is there 2 wires from the electronic ones I can ignore so i'm able to use a micro switch, or am I stuck with the electronic coin acceptor?
Hi there,
connect the black wire to the common terminal and white wire to the normaly open terminal on the coin micro switch leave the red wire disconnected just insulate it up so it can`t short on any thing
It works~ Amazing! Thanks for your help!
