Want To Buy
ThisGuy
New york
I’ve had a dark seal 2 pcb for a while now and I’d love to be able to convert to wizard fire the English version. I have all I need to create them but I’d rather not mess with the old EPROMs I’d like to keep the stickers looking original for when it’s time to sell it and I don’t have required EPROMs to create new ones.
Does anyone have these EPROMs available and can burn English roms for me? If so please let me know price and shipping cost to New York 11714
Thanks
sounds like a job for buyicnow.com
buyicnow.com sounds like a great idea but Im not exactly sure which eEPROMs I need to get created. If nobody can do it here I may just buy some chips and play around with it until i get it. I was hoping to avoid that though
I’m on mobile so I can’t easily compare anything but it should all be in MAME.
https://github.com/mamedev/mame/blob/master/src/mame/drivers/rohga.cpp
Every rom has a CRC value so you can see which ones are different between DS2 and WF. My guess is all the gfx are identical, most of everything else is too. You’ll have maybe a sound rom or some program roms that are different.
Then as for what chips, look at the size of the actual file and count the pins of the actual chip. The chips might even be labeled. But if they’re not just use this guide to pick the right chip: https://wiki.arcadeotaku.com/w/EPROM
So e.g. file size 256k bytes) is 2m (bits) and a 32 pin of that would be 27c020 or 27c2001
It's just two 1024 kbit eproms and one 512 kbit eprom. The ones that go to 3A, 3D and 20R respectively.
je-00.3a, je-01.3d and je-06.20r from wizdfire.zip for Wizard Fire (Over Sea v2.1)
jf-00.3a and jf-01.3d from wizdfireu.zip for Wizard Fire (US v1.1). You also need je-06.20r from wizdfire.zip
Easy peasy.
