L
loscanones
Well, open it ( just remove the Netdimm card) and check. It will be interesting to see if you have a "G" Japanese Bios.Not sure about the Naomi motherboard bios
Of the red games I've only played Illvelo and Border Down. I can definitely reset with Illvelo without test button. Border Down I cannot.Rewrite - are you saying you can reset the games in RED above without using the test button work around? If so; there must be something with the bios or firmware of the net dimm board that affects each games ability to reset with the net boot.
Interesting - lets keep the discussion going and we may get the bottom of it.
Does not work if netbooted if I remember correctly. Only works from a CF card.Street Fighter Zero 3 Upper does NOT work on my system. - Error 02 - THIS GAME IS NOT ACCEPTABLE BY MAIN BOARD. Guess whatever's in there is not a JP BIOS.
Ah, good to know. Then my BIOS remains a mystery to us all .Does not work if netbooted if I remember correctly. Only works from a CF card.Street Fighter Zero 3 Upper does NOT work on my system. - Error 02 - THIS GAME IS NOT ACCEPTABLE BY MAIN BOARD. Guess whatever's in there is not a JP BIOS.
Wrong. On my system is running fine, netbooted, Japanese BIOS.Does not work if netbooted if I remember correctly. Only works from a CF card.
Positively, your BIOS is NOT Japanese.Street Fighter Zero 3 Upper does NOT work on my system. - Error 02 - THIS GAME IS NOT ACCEPTABLE BY MAIN BOARD. Guess whatever's in there is not a JP BIOS.
It's probably Eprom version dependant..Wrong. On my system is running fine, netbooted, Japanese BIOS.Does not work if netbooted if I remember correctly. Only works from a CF card.
Yep, working only with Japanese versions.It's probably Eprom version dependant..
Yeah, it`s like the old ones.In order to make the game reset, you should connect pin 8 of the MB3771
Post a picture of it please. Did you track it to where it goes?Yeah, it`s like the old ones.Only difference, it`s MB3773 - version with a watch-dog timer. It`s a 5 minutes job to hook it to Raspberry.In order to make the game reset, you should connect pin 8 of the MB3771
Now i have have to turn dark side and try to run a script in RaspberryPi in order to send the reset signal with AW games.
To be honest, i was thinking at this method as better option than executing reset through Netdimm, i always liked the hardware side.
I found an old Naomi1 board in my stuff (it`s amazing what old people can store) and i will use it as a testing field. I do not want to destroy the good one, this will make me very nervous.
Well, first it should boot it up. I`ll order the Supercap first and test the signals. Hopefully it will work.
Does anybody wants to step forward for RaspberryPi script
I'd be very happy to see someone posting a tutorial about how to make your own raspberri Pi from scratch.I wish I had any knowledge of the RaspberryPi script as I would love to help, but have no experience at all.
It is really exciting to hear you are tackling the issue and looking at a resolution to the AW games (and some Naomi games).
If I can help in some way; would definitely do so. Good luck - looking forward to hearing your results! This would be a great improvement for those of us net booting with Raspberry Pis - keep at it please.
got this somewhere.I'd be very happy to see someone posting a tutorial about how to make your own raspberri Pi from scratch.I wish I had any knowledge of the RaspberryPi script as I would love to help, but have no experience at all.
It`s going to PIN2 of LVC08A.Post a picture of it please. Did you track it to where it goes?
Can you post both versions that you use, so others can also test it and eventually play it?Just want to point out that I've got SFZ3U working on my netboot Naomi using an Export BIOS (with the latest official netboot firmware, 4.11 I think?), but I had to use one of Deunan Knute's patch tools on the ROM to make it work, which converted it to Alpha 3 Saikyo Dojo with US character names. Doing this causes some relatively minor text issues such as causing the intro spiel for each character and the ending text to not appear, but other than that it plays fine and it boots consistently.
on offset 428Can you post both versions that you use, so others can also test it and eventually play it?Just want to point out that I've got SFZ3U working on my netboot Naomi using an Export BIOS (with the latest official netboot firmware, 4.11 I think?), but I had to use one of Deunan Knute's patch tools on the ROM to make it work, which converted it to Alpha 3 Saikyo Dojo with US character names. Doing this causes some relatively minor text issues such as causing the intro spiel for each character and the ending text to not appear, but other than that it plays fine and it boots consistently.
