Groove coaster controller usb mod
Futaba Tori
San Diego, CA, US
I was wondering if it would be possible to mod an arcade groove coaster controller to a usb interface and then make it use xbox 360 drivers. I don't own a groove coaster cab so I don't remember if it already uses usb but from what I remember it uses its own cable. Just wondering if it is possible and what tools I would need to make it work.
Sure, you could wire up the original controls to an encoder. It's basically nothing more than two buttons and two joysticks.
Would there be a best groove coaster controller like from a specific game to get? Or should I just try to get a gc4max controller?
The cabs are all the same, it's just the software that has changed over the years.
Why would you need to update it? The newer updates just have more songs, but they're all locked unless you connect to a network.
While you are right, would it be possible to connect it to a network over ethernet and it just work fine? Or is it like Project diva where you need a separate box for net, and would there be a way to set it to free play?
No, you can't just connect it to a network.
Free play works. It's just most of the content is locked when it's offline.
Would there be a way to unlock it (the songs and other stuff) or is it streamed over the network? Also does it work like Project Diva where you need a network box or something like that? (I know that in PDAFT there is a box in the cab that connects it to the servers or something)
