I recently got a Sega Astro City. The cabinet came with its original 2 pin (=not grounded) Japan/US plug and an internal stepdown (I live in Spain, where there is 230V, whereas the cabinet originally accepts 110V) The cabinet is designed to be grounded via a nut coming from behind, next to the power cord.
Here’s a picture of its original state:
Bottom right you can see the original non-grounded power cord coming into the cabinet and the nut with 3 green ground wires attached to it.
In order to ground it, I decided to replace the power cord by a EU grounded one, and to attach the new cable’s ground to the aforementioned nut.
Here’s a pic of the result:
However, I’ve been trying to double check this is all correct before turning it on, to avoid breaking the PSU or something else (like some user did while trying to do the same! Although I think due to an unrelated reason). I’ve found many related posts here and there, but couldn’t find anything conclusive.
Questions:
I have VERY limited electricity knowledge, so any help would be super appreciated.
Thank you!!
Questions:
- Does this mod make sense?
- In terms of there being an internal stepdown (connected to the two wires coming out of the top of the noise filter of the top of the picture), does this affect the way grounding has to be done in any way?
- There was a ground cable, the one coming from the coin mech, that was detached… not 100% sure where it should go, but based on the size of the cable, I’d say it goes attached the back of the coin box, together with other grounds. Any reason why it could be originally detached? Is it OK I reattach it?
- Anything else I should be aware of/check/test before going ahead?
Thank you!!
