r67055
Hungary
Hello.
there is a gun smoke pcb that shows a white image after switching on. It is remarkable that the body gives a picture in a standing position, but it looks as if it has frozen. I don't know how to work correctly in the chin of the body. Can you help me?
Thanks
Check the ribbon cables and connectors, I experienced the same issue on my board.
this is what i used.tested on a test table. not in a cabinet
Are you sure the game is running at proper+5V/5.1?
The board interconnectors, as Caius mentions, they are the little ribbon grey flat cables between the boards, that's what you should check.
I measure 5.1V in the tank. I replaced the gray connector with a reliable working one. The screen has not changed.
Yes. me too. I also have a bootleg pcb. That works. I replaced it with that
bootleg does that. Is it possible that for some reason it cannot test the ram and freezes?
With the help of the bootleg pcb, I found out that the error is in the lower pcb. I'm thinking of a RAM error.
