Gunslinger Stratos 3 Error?
hmmm... I've swapped both gun boards already and the fast i/o and still had the issue. The bios in the new x3 I have is v1.0b16, wonder if that is why it might not be reading the hd?
I also installed a multi in it to test and change the bios, some of the controls on the guns work on the multi, but all the others are disabled.
hmmm... J'ai déjà échangé les deux cartes de pistolet et les E/S rapides et j'ai toujours le problème. Le bios du nouveau x3 que j'ai est la v1.0b16, je me demande si c'est pour cela qu'il ne lit pas le disque dur ?
it's possible but not sure,this information must be confirmed by someone.
Can rule the bios out, I am not sure why the other x3 can't read the hd but I downgraded the bios to the same as yours and still nothing.
Guns work in test mode, nesica card reader works, ive swapped guns, swapped gun boards, swapped fast i/o, took apart the 2d sensors and reconnected them all.
Might just pass this machine off at this point.
Last thing I am going to try is to rip the game and stick it on the multi and see if it loads properly.
Hello,
So does it works now with the rip game @CaptainCrazy ?
