edwin128
Hello.
I have a multi-bios naomi1 working fine with a netdimm firmware version 3.13.
I got a naomi2, I don't know which bios has because it's not written in the eprom. Without the netdimm it boots, shows error 1 and I can access the test menu.
Once I put the netdimm, it gets frozen in the booting screen. it does not show any error or I can access the test menu. I put the netdimm back the naomi1 and it works fine. Also, I did the test in the test menu and it seems is fine.
What could be causing these problem? I see some jumpers in the naomi2 mobo, I did not touch them. I should change them to get the naomi2 to boot with the netdimm.
Thanks in advance for your help.
