fixed.Please people, STOP trying to run arcade hardware on FUBAR hardware.
If your CMVS is wired with DB15 similar to HAS it should workHello. Will the Sega Saturn to JAMMA joypad converter work with a consolized MVS? If so How do I get one? Thank you
It's a consolized mvs from neotropolis It should work.If your CMVS is wired with DB15 similar to HAS it should workHello. Will the Sega Saturn to JAMMA joypad converter work with a consolized MVS? If so How do I get one? Thank you
patience is not one of your strengths right?Hello?
Ok, when will they be back up?Sorry, all HAS units as well as Sega Saturn controller adapters are on hold.
For quite some time I was curious how much current the boards ACTUALLY draw, to make some qualified decisions on wire gauge, so have done some measurements:This is clearly a mistake in the manual. A 3A PSU is more than enough.Still a valid point that a 2A rated PSU should be avoided.Actual current specification for the NeoGeo MV-1FZ is 5V 7A
You would need a PS2 to supergun DB15 controller converterhello world
I am newbie in arcade supergun and I need some info about HAS.
Hon to work the mapping? Can use one specific mapping per game? Can save it?
I will use it with cps and mvs system. My config PS2 HRAP 2+ OSSC. I xould like use scart output.
Last think does exist model with ps2 controller input.
THX
THX
The mapping works by holding two buttons and pressing start. A LED turns on and then you push which button you want mapped to what i.e you hit whatever 1 will be 1 time, 2 will be 2 times, 3 3 times, etc and then hit start. This mapping is then saved until you change it again.
I don't know yet, but if all works out it will be ~3 months from now.Ok, when will they be back up?
Thanks
It's built into the HAS itself so it will work with any controller that is plugged into it. I swap between using an undamned usb encoder and saturn pad currently.I didn't know you could map buttons as well? Where can I find this? Does it work with a snes controller as well?You would need a PS2 to supergun DB15 controller converterThe mapping works by holding two buttons and pressing start. A LED turns on and then you push which button you want mapped to what i.e you hit whatever 1 will be 1 time, 2 will be 2 times, 3 3 times, etc and then hit start. This mapping is then saved until you change it again.hello world
THX
Cheers
Thank you. Looking forward to them being available again.I don't know yet, but if all works out it will be ~3 months from now.Ok, when will they be back up?
Thanks
I don't have a HAS. That's a great feature.It's built into the HAS itself so it will work with any controller that is plugged into it. I swap between using an undamned usb encoder and saturn pad currently.I didn't know you could map buttons as well? Where can I find this? Does it work with a snes controller as well?You would need a PS2 to supergun DB15 controller converterThe mapping works by holding two buttons and pressing start. A LED turns on and then you push which button you want mapped to what i.e you hit whatever 1 will be 1 time, 2 will be 2 times, 3 3 times, etc and then hit start. This mapping is then saved until you change it again.hello world
THX
Cheers
Is this in "steady state" or during bootup, we all know inrush current can be brutal.For quite some time I was curious how much current the boards ACTUALLY draw, to make some qualified decisions on wire gauge, so have done some measurements:https://wiki.arcadeotaku.com/w/PCB_Power_Consumption
Hi, I see this is the PSU recommended by @RGB, but on Meanwell site, browsing in the "Video Game Power Supply" I see the MWP-608 https://www.meanwelldirect.co.uk/products/104w-ac-dc-triple-output-for-video-game-3/ which is a triple output AC-DC PSU 5V, 12V and 24V. Is MWP-606 superseeded by this one? Is the 608 irrelevant having triple output?This is the PSU recommended;
https://www.meanwelldirect.co.uk/pr...-2/104w-ac-dc-triple-output-for-video-game-5/
