Derick2k
NYC, USA
@Apocalypse
Any chance you have worked on M84 conversion roms??
I know you can convert Major Title to R-Type II,
But are conversions from lets say Major Title or Hammerrin Harry to Ken-Go or Cosmic Cop doable as those would be more desirable games to play.
which ones are those?
Irem84 only has 5 games:
Cosmic Cop
Hammerin Harry
Ken-Go
Major Title
R-type II
To be confirmed but to me games can be grouped as follow:
- R-Type II, Major Title
- Ken-Go, Hammerin' Harry, Cosmic Cop
Cool, I have a couple of Hammerin Harry boards I bought a while back, if you ever make patched roms, I would love to convert them to Cosmic Cop & Ken-Go.
Humm...
It seems I was mistaken somehow.
According to MAME:
MAME said:
M84-A-A (bottom board) (most games)
M84-D-B (bottom board) (found on lightning swords / kengo)
MAME said:
// M84// is the upd71059c present and unused, or has it been removed from the PCB? it isn't needed beacuse the V35 has it's own IRQ controller.
static MACHINE_CONFIG_START( cosmccop, m72_state )
/* basic machine hardware */
MCFG_CPU_ADD("maincpu", V35,MASTER_CLOCK/2)
MCFG_CPU_PROGRAM_MAP(kengo_map)
Although sound hardware is different I'm not sure it makes a difference from a software point of view.
If so then any M84 game can be converted to any M72/M81/M82/M85 game.
Painful part is ROMs are mostly soldered.
Well, that is good news. The soldering part I can get over, the incompatible hardware part was a tearjerker.
I'l order the EPROM's and follow this conversion guide for my Hammerin' Harry board and let you know how it goes.
I've never done this conversion but I've always wondered why there was wire patching involved. Isn't it possible to do no wire hack at all by handcrafting the appropriate PAL?
Or is it an other hardware limitation I don't get yet (missing address lines?).
I've never done this conversion but I've always wondered why there was wire patching involved. Isn't it possible to do no wire hack at all by handcrafting the appropriate PAL?Or is it an other hardware limitation I don't get yet (missing address lines?).
That is Greek to me my friend =). I'll give the conversion a shot anyway. I won't cut the trace as suggested though. I'll lift the ERPROM leg and run Kynar wire to the point to preserve the board. If all is well, great! Dig deeper from there if needed.
It is going to take a good 3 weeks for the EPROM's to get here. I have the dip sockets already. Can't wait!
Good news! Let us know how it goes and take some pics please :)
If you get tired of waiting you could always socket your original ROMs in the meantime. :D
It seems IC7 is a 32kB RAM.
That is Greek to me my friend =). I'll give the conversion a shot anyway. I won't cut the trace as suggested though. I'll lift the ERPROM leg and run Kynar wire to the point to preserve the board. If all is well, great! Dig deeper from there if needed.It is going to take a good 3 weeks for the EPROM's to get here. I have the dip sockets already. Can't wait!
I wonder what cutting that trace does then? If it is just 32kB RAM, how does running it to a capacitor at C36 do anything? This is all Greek to me so I am probably making an ass out of myself even by asking.
C36 is just a point where you can find ground I guess.
Top left pin is A14 so grounding it means you use only the lower part of the RAM.
I had a look in MAME and discovered M82 has twice much video RAM 2 than M72:
MAME said:
static ADDRESS_MAP_START( m82_map, AS_PROGRAM, 16, m72_state )
AM_RANGE(0x00000, 0x7ffff) AM_ROM
AM_RANGE(0xa0000, 0xa03ff) AM_RAM AM_SHARE("majtitle_rowscr")
AM_RANGE(0xa4000, 0xa4bff) AM_READWRITE(palette2_r, palette2_w) AM_SHARE("paletteram2")
AM_RANGE(0xac000, 0xaffff) AM_RAM_WRITE(videoram1_w) AM_SHARE("videoram1")
AM_RANGE(0xb0000, 0xbffff) AM_RAM_WRITE(videoram2_w) AM_SHARE("videoram2") /* larger than the other games */
AM_RANGE(0xc0000, 0xc03ff) AM_RAM AM_SHARE("spriteram")
AM_RANGE(0xc8000, 0xc83ff) AM_RAM AM_SHARE("spriteram2")
AM_RANGE(0xcc000, 0xccbff) AM_READWRITE(palette1_r, palette1_w) AM_SHARE("paletteram")
AM_RANGE(0xd0000, 0xd3fff) AM_RAM /* work RAM */
AM_RANGE(0xe0000, 0xe0001) AM_WRITE(irq_line_w)
AM_RANGE(0xe4000, 0xe4001) AM_WRITEONLY /* playfield enable? 1 during screen transitions, 0 otherwise */
AM_RANGE(0xec000, 0xec001) AM_WRITE(dmaon_w)
AM_RANGE(0xffff0, 0xfffff) AM_ROM
ADDRESS_MAP_END
Still I wonder if it wouldn't be possible to accommodate that with code modifications.
I see. Makes great logical sense. I learned something here.
Don't sweat it for now Boss. I'll follow that guide categorically and see how it goes. I will report back what I find.
bastards.
the only reason to make half the ram mirror itself is if they are acessing it at different banks for protection.
bastards.
No protection on R-Type. Actually it's the only M72 game not equipped with a MCU for protection.
@Apocalypse so from All these MXX boards which one is in your opinion the preferred. I mean the one that could accomodate more games because of the amount of RAM and availabilty? M82?
