cma019
hong kong
I have recently bought the CPS2-multi champion edition and am seeking for a suitable board.
Could you please advise if this board looks fine and can be installed easily ?
From seller's description, the board is working fine
Thanks a lot.
Yes. That one is good. It’s got the JST header so you can use a key writing wire direct from the CPS-2 to your multi PCB.
Thanks djsheep. how about battery? i saw the user manual it requires to be battery suicided. i cant find any battery on the board.
The battery has already been removed. Looks like it’s most likely running decrypted ROMs. Which isn’t a issue here because the multi kit will require removal of those.
As long as the board is working, it’s a perfect candidate.
