This is driving me nuts.
As long as i don't have any programmer that supports this sop44 and i could not find any old Wellon VP that was supporting it (like VP480, wich is impossible to find at least on my end), i would like to try making an adapter for the TOP3000 (complete or bank switched).
Datasheet for MX26L clearly specify the ic is in WORD 16bit mode only (4Mx16) so i was wondering, since the beginning, how the hell did people (mostly Joerg/Arcademodbios, i must say) managed to use it in BYTE mode (8Mx8bit)?
The Highest sop44 that TOP3000 can handle (last version, 8.XX) are: MX29L3211 (4Mx8, 3V) and M27V320 (same). They are basically the same exept they differ on PIN 1 and PIN 33.
This will necessarly involve more file splitting/bank switching as both of these supported sops are only 4Mx8.
Can you guys help me figure out the configuration of these differences in order to have my top3000 able to write and read 26L as 29L or 27V?
I'm super-confused about.
Is it possibile to adapt the 26L, by bank switching, writing it twice (4M x2) by toggling HI/LO on the most upper adress, in this case, A21 @pin1?
Datasheet of the 26L saying that, in order to write on the device, CE and WE must be LOW, and OE must be HI.
WE is on PIN33 of the 26L
and
BYTE is on PIN33 of both supported devices (29L and 27V)
From what i've understand, BYTE is the pin for selecting the BYTE or WORD configuration. To use it as BYTE, the pin must be LOW state.
I was thinking that 29L3211 was the mostly good one to adapt for since this ic got WE on pin 1 (27V does not have it all, no idea why), but unfortunatly that shitty programmer was giving me an incorrect ID check and i'm not sure if you can disable it somehow (or is it because of different pins)
Please someone help me out is this could be a thing, i'm trying to understand if this is possible somehow or not.
Thanks
and
Thanks
