ItsACerealWow
Hello,
I'm a complete beginner when it comes to arcade PCBs and superguns, but not to retrogaming in general (I understand concepts like sync, voltage levels, etc. in regards to retrogaming setups). I recently acquired my first supergun, the HAS, back in February.
I have a lot of questions and confusion when it comes to connecting a Mortal Kombat 1 arcade PCB to a HAS into a CRT or PVM
Here's my setup for reference-
I recently picked up a working Midway Y-Unit Mortal Kombat 1 PCB and sound board, along with the proper cables to connect it to the sound board and a kick harness. The only thing I'm still missing is a Volume Pot, so I will be leaving the sound board disconnected during any testing until I pick one up.
What do I need to know before I get started? I've heard that MK1 Y-Unit PCBs have compatibility issues with some displays due to a very low sync rate. I've also heard something about it needing -5v for the audio processing?
I just want to get a good primer before I connect everything for fear of damaging the board or any of my equipment. (I know SuperG has a disclaimer about not using superguns with the gcomp but I've heard the HAS is safe to use. I don't know if having the signal converted from RGBs to YPbPr will have any negative effects on passing the video signal through properly.) Previously, the arcade PCBs I've connected to my HAS were much simpler- Data East's Avengers and Konami's ALIENS- just plug and play, really- but it seems like the MK1 boards have a lot more factors to consider and potential issues.
Thanks for any help the community can provide, and I hope you'll forgive me for being a total n00b (saibot)
HAS Supergun
+MWP606 power supply
+8pin mini din to RGB SCART cable
+(optional) HAS JAMMA extension cable
+(optional) Sega Saturn controller adapters, undamned USB controller adapters
32" Sony WEGA Trinitron KV32FS100
+accepts Component (YPbPr), S-video, composite and RF video
+8:2 gcompsw switch between consoles and television
+I use a Shinybow SCART->Component and a RetroTINK SCART->Component converter for the HAS and Dreamcast
13" Sony Trinitron PVM-1353MD
+accepts pretty much anything you can throw at it - RGBs, RGBHV, Component, S-Video, Composite, etc.
+I use Line 1 for Component, running from the second output of the gcomp
+I use Line 2 for RGBs, which I connect using RGC's SCART to BNC cables and a simple phono adapter for audio
(All video cables running between equipment are high-quality, shielded cables)
