chacal231077
France
Hello
I would like to convert my Version 3.0 to Revision 4.0 ^^
What are the Eprom to burn :?:
Thanks you ;)
ok thanks you :) ;) :thumbup:
Just one last question
what is the model of eprom to reprogram not to touch the original version ?
Ok Thanks You
Is this the last revision of the Y-Unit that can be installed? ?( :?:
Ok Thanks You
No ... this is what @Mitsu said in another place ... "I'm pretty sure 4.0 was the same on T-unit and Y-unit. I think 5.0 was mostly an update tweaking the way the game ran on the T-unit" ... hope it helps you ^^
ok Thanks But the other version turbo version 3.0 ,3.1 & Ninja it is necessary to the Little PCB?
You have a modified/hacked board there with Turbo Ninja (unofficial hack like the "Rainbow Edition" was for Street Fighter 2). The first thing to do is dump those 2 roms in the pic and post them here so we can check if they are in mame, that could be an undumped revision. Then after that if you want rev 4 you would keep that daughter card and rom removed and then you would program 2 other roms with the rev 4 from mame.
Do not reprogram those roms pictured, you would be throwing money away, that kit has a value, you can sell it on ebay in 10 seconds.
  • Like
Reactions: nem
