Kujako
USA, California
Tried a number of options over the years, including the ones JNX lists, none have really been a home run. I know folks have designed and built some decent ones, but I can't find files or sources. So, anyone have any recommendations?
Thanks,
EDIT: Alternatively, anyone have a recommended 3v supercapacitor to use instead?
Example: https://www.ebay.com/itm/192664230986
I use these in the OMVS builds I made, they work well but will require shaving off the mask to expose the ground plane:
Dahszhi Button Cell Battery Holder for CR2032-10pcs https://a.co/d/5Eoxdpo
So you're going to a secondary pad for the positive connection? Interesting, hand't considered that. My only concern here would be the extra width this ads for systems going into a consolized case. Not found a good fit for those. Wracking my limited knowledge on the subject re: supercapacitors since that's such an easy solution.
Edit: might take some measurements and see if a similar CR1620 holder will work.
Edit 2: turns out I had some around for use in GameBoy cartridges, same issue with the overhang unfortunately.
I havent seen a JNX case internals yet, but I believe that a CMVS Ultra, Omega and OMVS case all allow some space to the left and right edges of the MV1C. I have a PCB I used previously that lines up with the holes, but I just went with the socket for ease of installation
Looking at an old school aliexpress "CBOX", things are pretty tight. But one option would be to go somthing like this.
For what it's worth, I've battery modded multiple boards, and the ones JNX recommends always worked out fine for me, and even fit just fine in a case without much clearance.
I have some (same part number ordered from Mouser) but they don't align right. Always have to build a bridge for them to connect to. I dont know if the dimensions changed or if I just have ones that are a different size but they've never worked well.
More and more I'm thinking of going the supercapacitor route, something around 10F, can't think of why it would be a bad idea.
Yeah that's what I was looking for, but availability is limited. Had the files been posted I'd build a run of them myself, but I'm too busy (lazy) to do a design myself right now.
What I'm considering is using a 10 Farad 3V supercapacitor with an ESR of ~0.02 Ohms at 20c. That seems like it should work perfectly, but I admit to not having done all the math required to know for sure... but for comparison most LIR2032 coin cells batteries are in the 0.02-0.03 Ohm ESR range.
Yeah, it's not a perfect fit, but it didn't bother me. If you do ever try a supercapacitor, please let us know how that goes.
I've ordered a supercapaitor, still mulling if I'll use it. If I do I'll definitely post here. I'm just trying to think through how I would test it other than letting it run for a year or two.
Edit: thinking through it, fairly sure the capacitor I ordered won't work... but this is where I get a bit out of my depth.
i = 0.005amp (much lower in practice)
Δt = 10^6 seconds (one month of shelf life)
Vmax = 3.7-4v (what is supplied to the battery/capacitor by the charging circuit)
Δv = Vmax - 3 (3v being what the RAM needs to stay alive)
𝐶 = 10 farads
So time, voltage, current relationship to farads
𝑖𝐶=ΔvΔt
𝐶=iΔvΔt
So 10 farads is over kill, but... 3v isn't enough due to a higher Vmax.
With a 0.02Ohm ESR...
Vcap = VMax+(iR)
Vcap = 4+(0.005)(0.02)
So I need a voltage capacity of 3.7 to 4v realistically. Which I can't seem to find with a similar low ESR.
Looking at products that are designed to replace 2032 coin cell batteries, I think 5v is a more realistic target.
https://www.eaton.com/content/dam/e...pacitors-coin-cells-data-sheet-elx1175-en.pdf
It may be too early for any sort of reasonable thoughts, but I think I found a decent super capacitor option.
https://www.digikey.com/en/products/detail/eaton-electronics-division/PM-5R0V474-R/2185064
5v with 500mOhm ESR, but only 0.470F. That should be enough for a month or two of shelf life I think...
[Suspect math ahead warning]
Had formulas wrong yesterday I think... it's Δv over Δt. Multiply, divide same thing!
Δt = seconds
Vmax = 5v
Δv = 2v : Vmax - 3 (3v being what the RAM needs to stay alive)
𝐶 = 0.47 farads
𝑖 / 𝐶=Δv / Δt
(0.005)/(0.47) = (2)/Δt
Δt=188
seconds? That seems wrong...
Let's try another way.
𝐶=𝑖Δ𝑡 / Δ𝑉
𝐶=(0.005)(10^6)(2)
gets 5kF needed...
Think I see my mistake, amperage value is way higher than expected. SRAM should need around 1E-6 Amps (0.000001). I'll use 0.000005
𝐶=(0.000005)(10^6)(2)
5F needed for a month of shelf time, 1F if I use 1E-6 Amps. So 0.470F is less than two weeks... not great, but I think I'll try it anyhow. Worse case, I give up and go with a battery (well fire would be the worse case).
Edit: there's a 5F version https://www.digikey.com/en/products/detail/eaton-electronics-division/PHB-5R0H505-R/2770532
Question, checking a MV1C that via you show connecting to (-) on the battery isn't used by anything. Did you run a wire on the underside? Or did you scrape away the ground pane next to it. Still exploring options...
