Ziggy Cheetos Dust
I’m not 100% comfortable working with tubes and chassis, mainly because of their scarcity and pain to get repaired. So I was really careful not to snag any wires on components or neck the tube. The reason I had the chassis out of the frame and not disconnected at the neck board was that there was a black silicon blob holding the neck board to the neck. I didn’t want to tempt fate and tug on it, so I just carefully manoeuvred it around. I ended up accidentally tugging on the wiring anyways and it pulled the neckboard away from the silicon. The Toshiba chassis mounting holes didn’t fit nicely with the Exceleena frame plate, so I kept the plate it was on and drilled and threaded some holes in that and then attached that to the frame. I had to do a bit of mental spacial gymnastics to make sure the chassis connector and pots were at least somewhat accessible. Lastly I gave the tube a clean and dusted the chassis with a clean paint brush. No chassis in the dishwashers for me thanks. I scratched the powder coat when experimenting with frame . I’ve got some polyester tape on order the cover this area now.
