Orakelschaf
Germany
I had to swap the "HV ADJ" "X PRO" "B" Potentiometers and measured set values before:
- HV ADJ = 22k (47k Pot.)
- X PRO = 10,70k (10k Pot.)
- B = 329 (on 1k Pot.)
Since i am unsure if those are the really correct values: Can anyone point me in the direction for the correct values? - I am looking for the correct "B" Voltage too
Thanks alot!
- HV ADJ = 22k
- X PRO = around 5k on each side, pot set exactly to middle position
- B = 332 ohm
Thanks a lot for the values - Those help!
Is it possible to get the Voltage Value of B (just to make 100% sure it is set correctly on my friends cab) (if it is the same as on a M9 the voltage is measured between GND and T2)
