Hackcell
Heredia, Costa Rica
Well, finally my naomi 2 arrived from Cyprus... When I picked it at the customs agency I heard something wrong. When I opened it, found this:
https://flic.kr/p/HiCBoQ
And this freaking rusty capacitor:
https://flic.kr/p/GWkN5J
Could this loose heatsink mean a damage to the PCB? If not, what can I use to paste it again? Also, what's better? Shall I replace or remove the supercap?
Thanks in advance!
if you're handy with a soldering iron i'd remove the cap and give that area a very good cleaning. there looks to be some corrosion on the board as well so be gentle with it.
as for the heat sink im not sure if you need an adhsive thremal compound or and old compound will work.
also check out this thread talks about both areas you have issues with
[Repair Log] Sega Naomi
Oh man, i just got mine today too. Similar thing happened to me as well, but on mine the heat sink totally rattled around causing one of component to rip right off the board and i'm not sure if it's done any other damages. I've emailed the seller to see what can be done :/
