I started at the PSU and the ISO, both are outputting correctly. The bridge rectifier trsts ok. 130v rectifier amd HOT test ok, mosfet is ok. No ESR meter but the caps all check ok capacitance wise.
I'm at a loss as to why the fuse keeps blowing as if there's a short but since this is a cold chassis, everything tests as shorted to ground so I'm confused. I suppose I'm boiling down to the flyback is bad but I don't have a reliable way to test it. Ohms test on the anode seems to be ok.
I hear a K7000 is a direct drop in replacement for this chassis as well?
