Thank you but wich rev. is it?
On the drive there's already:
Cps2 A board rev.4
Cps2 A board rev.7
Cps2 B board rev.7
Later with less 10uf caps is: 93646A-3 and the one with all the caps is 93646A-4. So I guess they are rev. 3 and 4?
Work firewall blocked the drive so could not check if you guys already had these there.
Here is a picture of the rev 3 where you can see most of the 10uf caps replaced with ceramical
Sengoku Blade / Tengai PCB (SH404)
The lower 10uf was 16v, but I will replace both in 25v so thats why they are on same color on the picture.
1x 10uf 16v
1x 10uf 25v
6x 100uf 16v
3x 4.7uf 25v
1x 47uf 16v
1x 2200uf 16v
Added:
- Irem M107 (thanks to @AlxUnderBase)
- Tengai PCB (SH404) - Sengoku Blade (thanks to @nassekova )
about Irem M107, i can't say i'm responsable for because i just adapted System11's notes with the links of capacitors i've purcahsed and tried on my M107 board. Of course,the results are awesome and the M107 board is running without any issue :saint: ^^
Hy.
My m72 seems to have at C26 100uf 16v instead the 47uf 16v noted in the document.
Can anyone confirm? Or check if it’s wrong in the doc or just variation
Thanks
Just double checked on mine and there is a 47uf 16v on my board. It was not serviced before my recap but sometimes the value can change (I wrote this particular list very carefully and double checked every capacitor before swapping with a new one due to the board cost and rarity but I may have been wrong). Anyway if anyone else can check C26 will be great. The uf difference should not damage the board but it's better to report the right value without any doubt
Hy.
i can confirm too . mine have the same elna green capacitor ... the value of C26 on my board is : 100uf 16V . i checked now during the M72 update to the latest version . i replaced the Gal & MCU and i take a look on C26 and i can confirm there is 100uf / 16v 105celsius degrees
Ok then maybe my board had the wrong one I'll fix the file.
Let me know if you find other differences
Added:
  • Sony Playstation PU-20/668-413-12 PSU-1-486-302-11
  • Sony Playstation PU-8/1-658-467-23 PSU-1-468-159-11
  • Sega Saturn VA1 837-11613-01 Voltek S-7194
Fixed:
  • Nintendo Gamecube PSU Boards and DOL-CPU-10/20/30/10(P) (Some values were wrong, added CPU-10(P), PSU BOARD TDK-2.0, still need to add the PSU power brick)
Added:
  • Taito GNET + Sony ZN-2
  • Nintendo 64 CPU-(ALL NTSC) PSU JRC NJD-5168, 220v PSU ETYNT184SE 220v
Added:
  • PSU DOL-002 (UKV) Y1248 W124 220v
  • PSU DOL-002 (JPN) KP-C 1694V-0 100v
  • Atari 7800 CAO25234-001 (NTSC-U) C300633-001 rev. C (PAL)
  • Amstrad GX4000 MC0123C 2700-017P-4
  • Nintendo Super Nintendo - SNSP-CPU-02
  • Nintendo Super Nintendo JR - SNN-CPU-01
  • Sega Master System M4 PAL
  • Microsoft XBOX V. 1.0 - V. 1.1 - V. 1.4-1.5 - PSU FOXLINK FTPS-0002 Rev B-H 220v - PSU Delta DPSN-96BP-1 220v
Psikyo PS5 hardware cap list
Strikers 1999
100uf 25v - C1, C30 (6.3mm diameter, 2.5mm lead spacing)
100uf 25v in audio section - C20, C24, C26, C27, C28 (6.3mm diameter, 2.5mm lead spacing)
47uf 16v - C31 (5mm diameter, 2.5mm lead spacing)
2200uf 25v - C15 (16mm diameter, 7.5mm lead spacing)
4.7uf 25v - C2, C11, C18, C29 (5mm diameter, 2.5mm lead spacing)
10uf 16v - C4, C5, C9 (5mm diameter, 2.5mm lead spacing)
1uf 50v - C6, C10 (5mm diameter, 2.5mm lead spacing)
104 film/ceramic 10% tolerance - C13, C16, C17, C23 (5mm lead spacing) (somewhat optional)
Gunbird is the similar, but missing C2, C4, C5, C6, C9, C10 for one of the audio areas that's unpopulated. One extra 10uf16v for c31, and a few extra films 222k at c19 and c22.
BOM from Digikey attached, I haven't verified these yet but I'll edit this when I have. They're mostly high grade audio caps, and long life otherwise.
  • psikyo_ps5_bom.zip
