Skratcher
Ohio
I recently picked up a Harley LA riders cab, it has a 600w ATX power supply, it wasn't working at first(stuck on daughter board detected text) after messing with the wiring I got it to boot up and looks okay but the 5v is reading 4.8
I decided to try another ATX power supply I had laying around and it's reading about the same on the 5v line… weird
Is there no way to adjust the voltage on these ATX power supplies?
I have an orignal model 3 JQA power supply but I would need the harness connectors to re wire it, anyone know where to get those?
you need
1
https://www.digikey.ca/en/products/detail/te-connectivity-amp-connectors/176277-1/2328019
2
https://www.digikey.ca/en/products/detail/te-connectivity-amp-connectors/176279-1/2328021
3
https://www.digikey.ca/en/products/detail/te-connectivity-amp-connectors/176280-1/1153000
4
https://www.digikey.ca/en/products/detail/te-connectivity-amp-connectors/176278-1/2328020
and the pins
https://www.digikey.ca/en/products/detail/te-connectivity-amp-connectors/175152-2/2328002
Trying to wrap my head around how to re wire this mess back to the original connectors to fit the original power supply. Anyone have any suggestions on how to tackle this mind fuck? I’m not sure where to start re wiring this
oh boy.
hint: they are color coded.
Sega / Naomi / All Jap Machines.
Red = +12 Volts
Yellow = +5 Volts
Brown = +3.3 Volts
White and or Black = 0V or Gnd
The one thing I don’t understand is the “5v output” wires from the filter board.
They're not supposed to be connected to the PSU. You can connect them, but that's not the idea.
