So I have a New Versus City Sega control panel made by Seimitsu, and it fits a Seimitsu LS-33 stick which has a VF mounting plate. I'd like to put an LS-32 in it instead but the 32s are a bit larger and the screw holes to mount the stick don't line up. The VF mounting plate is a much smaller square than the SS and Flat Plate the LS-32 usually comes with, as I've tried both and neither line up correctly. I was looking to see if, and how, a larger squared stick could mount to the smallermounting post that resides under my panel.
I came across a post from the SRK forums which suggested this universal adapter plate along with a shaft extender, as the mounting posts under the panel come down a little bit (by 2cm I believe).
Anyone have any experience with this universal adapter plate? This seems as though it would be the ideal solution. I'd appreciate any feedback, help/suggestions, confirmation, whatever.
Thanks.
Thanks.
