Watching now. Glad to see everything went off without a hitch. Well... after all of the other headaches.
View: https://www.twitch.tv/videos/1464908121
That’s one of the things that makes this setup so specialWell, that's how the original works and this is following the original 100%
I do hope someone crazy enough to do this on Misterfpga.Players staying still can't work with this hardware. Each pcb can only output one match (2-players) so matching players and letting them stay in place can't work unless you split screen. Even then the pcb would need to be powerful enough to run two different matches while also running more robust net code. Obviously this is impossible.
I'd be down to help Steven assuming you're sauseege I think we've met. I also have 4 cps2 boards to help with and can bring a candy or two IF needed. Let me know if I can be of assistance.I would like to try to get this set up for CAX end of July. I might not have enough time to coordinate it though. I asked my friend bigtime for help since he has more kits than me. I have the 4 repro comm boards. We have plenty of cabs between us...
