OK, with help from my wife and no interruptions! All tests are with game in AirDrive test mode, the hex display showed LL and none of the cables to the rear cabinet attached, so should be like when you first tested your setup? (Driver board attached to game board & power)
Looks like signal 8 is the problem? Should be low? I've triple checked the result and it is 100% high for all tests. I've not re-attached the rear cabinet to see if that changes anything.
