Arcade machines are not known for their silent cpu/case fans. When they are located inside a cab, within an arcade hall, it is not a problem. But when you use them in your own house, with a supergun or inside your cab in your silent room, it seems as if you are next to a plane that is about to take off
No different is the Taito Type X family
Over at Taito Type X2 Upgrades and Mods, by @Cell, I saw which fans to replace the originals with.
Here is my process into changing them should you want to do the same.
What to buy
These are the fans I purchased, they are quite cheap.
Open up the casing
Remove the support bar
Remove the graphics card + JVS/Dipswitch support PCB
Note: the graphics card is connected to the powerPSU, you have to unplug the power cable.
Remove case fan from casing and replace with new fan
Note: mind the direction of the airflow, should be the same as the original
Replacing the CPU fan
Now comes hard part #1, in order to get to the CPU fan (without removing it from the board/cpu), you need to lift the whole motherboard from the casing.
I chose to leave all the power plugs in place; hence I lifted the powerPSU and the motherboard together.
Replacing the PowerPSU fans
This is hard part #2 and requires a bit of soldering. I chose to leave the fan cables in place and cut them inside the fan.
*** WARNING : Be careful opening up the PowerPSU ***
Reassembling your TTX2 again!
Now reverse all the steps to re-assemble everything. Below a picture where the case fan power cable should be (top) and the CPU fan (bottom).
Enjoy the silence
What to buy
CPU Cooler | GeLid Silent 7 FN-SX07-22 70mm |
Case fan | Cooler Master SickleFlow 120 | |
Power Supply | Scythe Mini KAZE ULTRA 40mm (2x) | |
Open up the casing
- Unscrew the top hdd-cover with your (multi)hdd
- Unplug the SATA cable and the power cable.
- Next, unscrew the full top cover. There are 3 screws on top, 2 on the side and 2 at back as well as 2x front side.
- Unscrew, on the side + in the front of the casing 2x2 screws from the powerPSU
- Unscrew the 7+ motherboard screws
- At the back, inside of the casing the power cables are bundled; open that clip to release the cables from the casing
- Lift the mobo + powerPSU together and place them next to the case
- Replace the CPU fan - there are 4 screws in the fan itself
- Unscrew 2x2 screws on the side of the PSU and 1 on top of the PSU
- Unscrew 2x4 screws to remove the fans from the PSU
- Cut the original fan wires as close/inside as possible to the fan
- Cut the connector from your new fan
- Strip the wires of the original wires and the one on your new fan
- Connect the red-red and black-black. I choose to solder them, probably more options on how to do this.
- Shield the just connected wires from touching each other
- Put back the new fans inside the PSU and re-assemble the powerPSU
Enjoy the silence
