FrancoB
UK
https://www.printables.com/model/222123-taito-vewlix-orei-hdmi-audio-extractor-mount
Mount to fit a OREI HDMI Audio Extractor to a Taito Vewlix arcade cabinet.
Two versions uploaded, one with an additional mount to fit a DC 5V Delay Relay Shield NE555 Timer Switch Module.
The mount fits to the existing bolts in the cabinet side that bolt the lower side covers on.
Remove the M3 screws from the audio extractor and fit to the mount using M3x8mm CSK screws.
If using the delay module, use M3x10mm bolts to screw directly into the plastic.
OREI HDMI Audio Extractor:
https://www.amazon.co.uk/gp/product/B07BHYXVTY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
DC 5V Delay Relay Shield NE555 Timer Switch Module:
https://www.ebay.co.uk/itm/154378763930
I was thinking about upgrading my monitor to HDMI and was wondering on extractor upgrades. This is awesome!
Where'd you get that power adapter ? I'm gonna need one and want to find out what to search for.
I'm glad you like it, I hope you find it useful. I'm currently using the stock monitors in my Dia Blues but with a HDMI>DVI cable. DVI doesn't carry audio, hence the need for this. It would still work with a HMDI>HDMI setup though.
The HDMI audio extractors came with a mains>DC power adapter but that's not pictured. Do you mean the PCB pictured in above post? If so, that's a delay switch for turning on the HDMI extractor a little after the cab/monitor has fired up. There's a link to the part I used in the post above and there's also some further information in [this] post.
Ahhh ok makes sense. For some reason I thought it was a power cable tied into the PSU, but that makes sense.
